Hydraulic Top Link Recommendations Wanted
   / Hydraulic Top Link Recommendations Wanted #1
Pecosbill7
Fredericksburg, Tx
John Deere (2)
John Deere 5320. I’ve been threatening to get a hydraulic top link for many years but never think about it unless I’m turning and turning the existing manual link. I want to know which links you all favor and which ones you think are junk, as I only want to do this once (well, twice since I have two tractors). I see that Tractor Supply carries some but I haven’t been overly fond of other parts I’ve gotten there over the years, so I’m looking for recommendations and why you like what you like. Thanks.
Bill
   / Hydraulic Top Link Recommendations Wanted #2
Are you looking for a cat 1 or cat 2?
What ever you end up with it should have the locking valves on it.
Then you have to decide what length you want, the following page has cat 1 ones,
Category 1 Hydraulic Top Links
Mine is a cat 2 and this is the style that I use;
   / Hydraulic Top Link Recommendations Wanted #3
Look at the following link. Get the asked-for dimension. That should be what your mid-stroke dimension would be, plus or minus.
I normally recommend a 3" dia cylinder with a 1 1/2" dia rod having a working length of 19 1/4"- 27 1/4". This seems to work well for this application.
Typically the 5000 series JD tractors do not have poor-quality control valves for the rear remotes (SCV in JD lingo), so a check valve is most likely not needed, but can be provided if requested. ;)
“Are you looking for a cat 1 or cat 2?
Thanks. Most of my implements are cat 1 but I do have a few that are cat 2. I’ve been able to get away with a cat 1 top link with a bushing inserted in the top link insert in the tool.
   / Hydraulic Top Link Recommendations Wanted #5
100% positive getting my hydraulic Top and Tilt from Brian at FitRite...(a.k.a. MtnViewRanch on TBN)!
He can hook you up with the right size and configuration based on your tractor, plus he supports his products.
Thanks, guys. I’m going to give Brian a call. I appreciate y’all’s input and advice.
I emailed Brian and he returned emailed me this morning. Not cheap but I'm going to run with it. Thanks again for your help everyone.
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
(1) 24ft Free Standing Panel (A51573)
(1) 24ft Free...
1272 (A50490)
1272 (A50490)
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
