Hydraulic top link length?
/ Hydraulic top link length? #1
UncleBuck1
Baton Rouge, LA
2011 MF 2660HD; 1964 JD 4020 (may she rest in peace)
I would like to purchase a hydraulic top link, primarily for use with a box blade. When my box blade is level the top link is 28" center-to- center; how much retraction and extension from level do I need?
/ Hydraulic top link length? #2
My recommendation would be for a 22"-32" working length. Gets you a little bit more retraction than extension and that can work in your favor when you have conditions-situations when you need the implement raised up higher.
/ Hydraulic top link length? #3
You can use your mechanical top link to find the feasible min and max lengths and use that as rough guidance. Hydraulic top links I see that would work have ranges of 22-30", 24-32", and 26-34".
/ Hydraulic top link length? #4
I can't add anything more than has already been said, but I will put a plug in for Brian at Fit Rite....great hydraulic top link setups! The one he built for my LS was perfect, and it simply toyed with a 1,400lb implement.
/ Hydraulic top link length? #5
Same here, happy with my gear from MtnViewRanch (same guy).
/ Hydraulic top link length? #6
Are you ever planning to buy a 3ph Quick Hitch? That would change things a little...
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
INSPECTION (A61165)
INSPECTION (A61165)
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2019 Ram 4500 4x4 S/A Dump Truck (A59230)
2019 Ram 4500 4x4...
26120 (A56859)
26120 (A56859)
