Hydraulic top link issues
/ Hydraulic top link issues #121
I'm doing my shopping for restrictor orifices and i saw the mini ball valve and was wondering if this could achieve the same purpose as the flow control valve? The restrictors are only $5 each and the flow controls are $50 each and the mini ball valves are $10 each.
I'd place a vote for the ball valves. Then you can completely turn it off, if need be, and lock it solid. And then it's easy to unplug, even if you have pressure in the line.
I sometimes restrict flow with mine as it's a lot faster to reach out the back window and bump it nearly shut, than to wind the knob in on my flow adjusters. Just my opinion, which is worth what I'm charging for it if you don't need to adjust it then you can always take the handle off once set to your liking.
I ordered the restrictor ports and the ball valves and we'll give it a shot. I'll try the ball valves first and see how that goes. The ball valves should be within reach from the seat. I don't care to fool with hydraulics as I always seem to get oil all over me somehow and eternally stain my pants like I've pissed myself, but I'm becoming obsessed lately and I have visions of adding some extra valves in the future.
/ Hydraulic top link issues #123
Good work. I hope the restrictors will fix your top link issues, I'd put a ball valve in the return/rod end hose at least, that's what I'm doing tonight to my new one. Handy if you need your rear remotes for something else, there was another thread with a guy using a 3pt woodsplitter having trouble connecting/disconnecting his toplink to run the splitter under pressure, for example. You never know what the future holds for you and your tractor. Just be careful if you use Teflon thread tape, that you don't get it in the hydraulic system as it can be a bit of a showstopper. Jams valves etc, if you have little bits get in there.
/ Hydraulic top link issues #124
Would you mind sharing your source for the mini ball valves at $10 each? Is it rated for hydraulic pressures? Thanks.
/ Hydraulic top link issues #125
The Parker type restrictions are more expensive, but they will give you precise, repeatable control, the ball valves, not so much.
The flow restrictions are also free flow in one direction, restricted opposite. The ball valves are going to be restricted in both directions which is going to be a bit difficult to get good metering.
Yes the flow restrictions are more money, but they do the job.
I would install so the flow out of the cylinder is restricted. That is called exhaust metering. The backpressure created on the cylinder outlet slows cylinder movement. Other people prefer to restrict on inlet. Just a personal preference
/ Hydraulic top link issues #126
Excellent advice!
The OP mentioned that he has two restrictors coming.
Given the problem that's given rise to this thread (possibly getting air in the cylinder due to fast flow?), would you suggest he puts one in each port or just the exhaust side? IF- it somehow is still getting air in there, would the restrictors hinder the bleeding of the cylinder?
As far as my assumption goes, one restrictor or two won't alter the flow rate
I look forward to hopefully getting this resolved this weekend. This has been a big hydraulic learning experience. Thank you all for sharing your knowledge and advice.
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
MASSEY FERGUSON 231 TRACTOR (A62130)
MASSEY FERGUSON...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
40' High Cube Multi Door Shipping Container (A60463)
40' High Cube...
2 Row Planter (A60463)
2019 TAKEUCHI TL10V2 SKID STEER (A59823)
2019 TAKEUCHI...
