Hydraulic tick - '64 JD 3020
   / Hydraulic tick - '64 JD 3020 #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
In the process of buying a 1964 John Deere 3020 with front end loader. When the tractor is sitting at a cold idle there is a tick sound every few seconds in the hydraulics. Sounds like a valve. The noise stops when you use the hydraulics and when the hyd oil warms up. Any ideas what this could be? Thanks.
   / Hydraulic tick - '64 JD 3020 #2
Check the frt hyd pump coupler for wear/looseness
Thanks for reply Jim. It does sound like the noise could be coming from there. I've tried to wiggle it few times now and there hasn't been any movement. Seems there is too much pressure on coupler or it's still good. Maybe I could crank engine by hand to remove pressure, then check for looseness? Will let you know if I figure it out. Thanks.
   / Hydraulic tick - '64 JD 3020 #4
Between the two-parts of the. corupler there usually is a hard peace of rubber / plastic if it's cracking or brittle it is most likely broken in peaces on the inside.
   / Hydraulic tick - '64 JD 3020 #5
If pump drive is the noise more than likely it's worn out bushings(parts key #4) or under extreme worn conditions the clamps(parts key #2) will require replacement.
1995 Rinker Captiva 190 (A53472)
1995 Rinker...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
