Hydraulic tick - '64 JD 3020
   / Hydraulic tick - '64 JD 3020 #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
In the process of buying a 1964 John Deere 3020 with front end loader. When the tractor is sitting at a cold idle there is a tick sound every few seconds in the hydraulics. Sounds like a valve. The noise stops when you use the hydraulics and when the hyd oil warms up. Any ideas what this could be? Thanks.
   / Hydraulic tick - '64 JD 3020 #2
Check the frt hyd pump coupler for wear/looseness
Thanks for reply Jim. It does sound like the noise could be coming from there. I've tried to wiggle it few times now and there hasn't been any movement. Seems there is too much pressure on coupler or it's still good. Maybe I could crank engine by hand to remove pressure, then check for looseness? Will let you know if I figure it out. Thanks.
   / Hydraulic tick - '64 JD 3020 #4
Between the two-parts of the. corupler there usually is a hard peace of rubber / plastic if it's cracking or brittle it is most likely broken in peaces on the inside.
   / Hydraulic tick - '64 JD 3020 #5
If pump drive is the noise more than likely it's worn out bushings(parts key #4) or under extreme worn conditions the clamps(parts key #2) will require replacement.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2020 CATERPILLAR 279D3 SKID STEER (A51246)
2020 CATERPILLAR...
New/Unused Quick Attach Rock Breaker (A51573)
New/Unused Quick...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
City of Buckhannon - Kawasaki 4010 Mule (A52384)
City of Buckhannon...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
