Hydraulic Suction filter help needed
/ Hydraulic Suction filter help needed #1
racerboy832
Connecticut
Deutz Allis 5220 w FEL and Backhoe
Hi Guys i'm trying to find a replacement suction filter for my grey market mini Ex. This is the one that sits in the tank. I'm having a hard time figuring out what size pipe filter to get. It is a tapered pipe thread. On the filter side the first thread shows 1.534 and the deepest thread into the filter comes up as 1.507 on my cheap harbor freight caliper. The inside of the actual pipe is 1.424 and outside is 1.685. It is a YSK filter. I can't get a part # from the dealer for some reason. Thank you.
/ Hydraulic Suction filter help needed #2
Make and model of ex? Dimensions of filter Dia x H ?
YSK number?
And pics always help!
IHI IS40G Mini Ex
No Numbers on the filter
/ Hydraulic Suction filter help needed #4
Is it just me, or does this look like a tank breather filter? So this is on the end of a pipe that sits inside the hydraulic tank immersed in oil and that pipe goes to the hydraulic pump inlet? Tank/housing/pipe and fittings pics?
/ Hydraulic Suction filter help needed #5
This is immersed in the oil tank. There is no IHI dealers near me. Closest one is 1-1/2 away.
/ Hydraulic Suction filter help needed #7
Measurements would indicate very close to 1 1/4 BSPT or 1 1/4 NPT OD is 1.65 but if the die is not set correctly it would cut undersize.
There are several companies that make 1 1/4 suction strainers. Being a suction strainer if the threads don't seal 100% will not really matter.
The local hydraulic shop said a 1-1/4 NPT threaded on but didn't feel correct. They said its probably British pipe thread. Does anyone know where I can get a 1.25" BPT suction strainer? It's kinda odd in USA
Anyone have any leads?
/ Hydraulic Suction filter help needed #10
Did the npt thread want to stay on? If so use some proper thread sealant and screw it on. Its only a suction filter so wont leak.
/ Hydraulic Suction filter help needed #11
Im no expert. but a British Standard Pipe, thread is always referred to the size of the hole of the pipe it serves. A 1/8th BSP will be for pipe with a 1/8th inch hole in the pipe, but for tapping the thread you need to drill something like 8,8mm if memory serves me right. A lot of the old grease nipples used to be 1/8 BSP but the treaded hole was about 3/8th inch.
/ Hydraulic Suction filter help needed #12
BSP size originally was for the inner diameter of the pipe, but use of stronger materials have changed that somewhat.
The following link let you download the document "How to identify Fluid Ports and Connectors." I have found it really useful.
It lists North American, British, Japanese, German (DIN metric) and ISO connections.
How to Identify Fluid Ports and Connectors
Kai
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
Iranch High-End Tricycle (A64119)
Iranch High-End...
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
1996 Champion 540P (A64126)
1996 Champion 540P...
(2) Tool Boxes (A62613)
(2) Tool Boxes...
