hydraulic stop valve or travel
   / hydraulic stop valve or travel #1
spo307
Levittown & Long Eddy NY
kubota L4400
I was looking to hook up a valve or pressure switch on a adjusting rod to my jd disk so i could set the high i wanna disk, besides making a visual indicator with a rod?? any ideas? thanks
   / hydraulic stop valve or travel #2
Is this a pull type disc? If yes you can purchase donuts/stops that slide over the rod on your cylinder to limit how much it retracts.
   / hydraulic stop valve or travel #3
How about a small $10 laser level on the tractor, and an indicating rod attached to the disc frame
After calibration for level, mark your stick in inches for the depth the cutters are in the ground.
If you had the T-N-T setup, you could be very precise.
yes kba pull type with wheel carrier
   / hydraulic stop valve or travel #5
Get the stops. Lower the disk to the depth you want then purchase stops to add up to the thickness needed on the cylinder. By adding or taking away a few your adjustments are quick and easy.
Some cylinders have a small switch on the end and when this switch hits an adjustable stop will quit moving also giving depth control.
   / hydraulic stop valve or travel #6
Stroke control, if that is what you want to use.
Welcome to Wadler Manufacturing.
http://www.royalbrassandhose.com/catpdf/ag_parts/261.pdf
http://www.norwest-mfg.com/catalog/TIL1000.pdf
http://baileynet.com/index.php?id=31&productcategory=1000027
If the valve is a solenoid hyd valve , then two stop switch on the cyl would work.
Just set it to break the voltage to the solenoid when the depth is right, and a stop switch at the full raise position.
Then all you would have to do is press a button.
its an 8x2 cylinder from tractor supply rod should be 1 1/8
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2017 Kubota M5-111D Agricultural Tractor (A52377)
2017 Kubota...
