hydraulic stop valve or travel
   / hydraulic stop valve or travel #1
spo307
Levittown & Long Eddy NY
kubota L4400
I was looking to hook up a valve or pressure switch on a adjusting rod to my jd disk so i could set the high i wanna disk, besides making a visual indicator with a rod?? any ideas? thanks
   / hydraulic stop valve or travel #2
Is this a pull type disc? If yes you can purchase donuts/stops that slide over the rod on your cylinder to limit how much it retracts.
   / hydraulic stop valve or travel #3
How about a small $10 laser level on the tractor, and an indicating rod attached to the disc frame
After calibration for level, mark your stick in inches for the depth the cutters are in the ground.
If you had the T-N-T setup, you could be very precise.
yes kba pull type with wheel carrier
   / hydraulic stop valve or travel #5
Get the stops. Lower the disk to the depth you want then purchase stops to add up to the thickness needed on the cylinder. By adding or taking away a few your adjustments are quick and easy.
Some cylinders have a small switch on the end and when this switch hits an adjustable stop will quit moving also giving depth control.
   / hydraulic stop valve or travel #6
Stroke control, if that is what you want to use.
Welcome to Wadler Manufacturing.
http://www.royalbrassandhose.com/catpdf/ag_parts/261.pdf
http://www.norwest-mfg.com/catalog/TIL1000.pdf
http://baileynet.com/index.php?id=31&productcategory=1000027
If the valve is a solenoid hyd valve , then two stop switch on the cyl would work.
Just set it to break the voltage to the solenoid when the depth is right, and a stop switch at the full raise position.
Then all you would have to do is press a button.
its an 8x2 cylinder from tractor supply rod should be 1 1/8
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2005 WhisperWatt DCA-70SSJU2 70kVA Towable Diesel Generator (A52377)
2005 WhisperWatt...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
4- 12 TOM JACK STANDS (A53843)
4- 12 TOM JACK...
1983 Case 580D (A47477)
1983 Case 580D...
