hydraulic stop valve or travel
   / hydraulic stop valve or travel #1
spo307
Levittown & Long Eddy NY
kubota L4400
I was looking to hook up a valve or pressure switch on a adjusting rod to my jd disk so i could set the high i wanna disk, besides making a visual indicator with a rod?? any ideas? thanks
   / hydraulic stop valve or travel #2
Is this a pull type disc? If yes you can purchase donuts/stops that slide over the rod on your cylinder to limit how much it retracts.
   / hydraulic stop valve or travel #3
How about a small $10 laser level on the tractor, and an indicating rod attached to the disc frame
After calibration for level, mark your stick in inches for the depth the cutters are in the ground.
If you had the T-N-T setup, you could be very precise.
yes kba pull type with wheel carrier
   / hydraulic stop valve or travel #5
Get the stops. Lower the disk to the depth you want then purchase stops to add up to the thickness needed on the cylinder. By adding or taking away a few your adjustments are quick and easy.
Some cylinders have a small switch on the end and when this switch hits an adjustable stop will quit moving also giving depth control.
   / hydraulic stop valve or travel #6
Stroke control, if that is what you want to use.
Welcome to Wadler Manufacturing.
http://www.royalbrassandhose.com/catpdf/ag_parts/261.pdf
http://www.norwest-mfg.com/catalog/TIL1000.pdf
http://baileynet.com/index.php?id=31&productcategory=1000027
If the valve is a solenoid hyd valve , then two stop switch on the cyl would work.
Just set it to break the voltage to the solenoid when the depth is right, and a stop switch at the full raise position.
Then all you would have to do is press a button.
its an 8x2 cylinder from tractor supply rod should be 1 1/8
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
CAT Skid Steer (A50322)
CAT Skid Steer...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2022 Padget Morris Electric Mobility Scooter (A54815)
2022 Padget Morris...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55218)
2015 Ford F550...
Engel 20' Boat (A50121)
Engel 20' Boat...
