Hydraulic Stick Saws
/ Hydraulic Stick Saws #1
JimR
Elite Member
Central Ma.
Kioti NX4510HST
Anyone own or use a hydraulic stick saw or hydraulic pruners off their tractor hydraulics?
/ Hydraulic Stick Saws #2
No. I saw a hydraulic pruner at the Kubota dealership several years ago. It was very heavy built and would have been quite a chore just to lug around. The heft of that pruner plus the weight of the hydraulic hose - you would need to have the strength of a gorilla to use it for long.
/ Hydraulic Stick Saws #3
Made one for the tractor. Sure been useful. Several manufacturers make similar saws.
/ Hydraulic Stick Saws #5
What use are you thinking about? There is also a circular saw version sold by Limbsaw. Home
/ Hydraulic Stick Saws #6
The tree trimmers were using a handheld hydraulic pole saw from the bucket of the boom truck.
I plan on using it around our properties. I did buy these yesterday for $200. Two loppers and the saw.
/ Hydraulic Stick Saws #9
wow,that is impressive. how does it work with the lower branches, just. tilt forward or…..?
Yes. The top is hinged and adjustable. Generally want to cut from the top to prevent binding. Being able to reverse gets you out of a bind.
I changed out the hose fittings on the saw. It does work on my remotes but the open loop valve is sticking when you release the handle. I'll get into that tomorrow to see what is causing the sticking.
/ Hydraulic Stick Saws #11
I use my LimbSaw yearly to keep tractor roads and duckhole levees trimmed up so mowing isn’t so difficult. Runs off of hydraulics is piped to front of loader from the #2 rear remote on the right side of bucket. It uses hydraulic fluid to oil the chain, which is adjustable. More oil cuts better but will leave a mess on the tractor. I turned mine down to a fast drip.
Sometimes used to delimb a trash tree that needs removing. Only cuts in a vertical plane but will take a vertical limb out if the blade can get started on an angle. Undercuts are possible to help cutting big limbs from pinching saw.
When I trim or take a tree out, the limbs get piled up for wildlife. Brush piles around my place are full of hopping, crawling, flying and biting things!
I did end up buying 3 Greenlee tools. One stick saw and two loppers for $200. I got in my standard hydraulic fittings the other day and went to work using the stick saw. Man does that work nicely. I also turned down the chain oil on mine. My front remotes run off one of my rear remotes just like you have. The price to run those hoses were around 1/4 of the price to buy and install a joystick setup for the front remotes. I noticed that this saw does not pull on my back like my Husqvarna pole saw does. I also used one of the hydraulic loppers I got and it works awesome slicing off 1" and 1 1/2" branches like cutting butter. Because these tools are only rated for 800 - 2000 psi I am running my tractor at an idle to use them. I noticed that the hoses are only rated for 2200 psi. Full throttle would probably blow these lines on me. I wish I had bought these years ago. What a time saver they are. Not to mention that i can use an IBC tote in my forks to get up to cut higher branches and have my daughter move me around.
Pallet of Hay Tedder Tines (A64119)
Pallet of Hay...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
SKID STEER PLATE GRABBER (A62613)
SKID STEER PLATE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2016 Nissan Titan XD 4x4 Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
