hydraulic steering help please
/ hydraulic steering help please #1
tyrus
norfolk (uk)
1992 case 235
my tractor , a smallholder st2030 (rebadged yagmur), has developed a fault the wheels turn in the correct direction each time the wheel is turned but i dont get a lock ie the wheel will continue to turn, if i don't turn the wheel constantly then the front wheels do there own thing and follow camber, any ideas and will it need specialist help or do you think it could be done by a amateur diyer.
any help or advice appreciated
ok thanks how do i get it out?
/ hydraulic steering help please #4
Fill to correct level .Follow suctionhose and tighter hoseclamps or fittings . Replace hydraulicfilter.
ok please bear with me, its a double acting ram, when i got the tractor the p/steering reservoir was leaking from the bottom hose, all oil tight now. is there a bleed screw or should it self bleed?
/ hydraulic steering help please #6
Air in the system is probably not your problem. If you can get the cylinder to full stroke in one direction and continue to turn the wheel in that direction, you most likely have piston seals leaking in the cylinder.
/ hydraulic steering help please #7
Doesn't steering with hydraulic cylinder also have mechanical linkage? If the steering turns there is something broken in the mechanical part. In example the bolt or key in steering shaft coupling to the steering box is broken/sheared/ missing. Or the key in the arm that the pushrod is connected to is sheared. Isn't steering wheel slipping on the steering shaft? If all those things are good then the problem is internal to steering box.
/ hydraulic steering help please #8
I was thinking either bad seals in the steering cylinder or the steering wheel itself is loose on the column shaft. Id check for a loose steering wheel first. Then for seals in the steering cylinder. Then have the steering valve tested.
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
3pt Hydraulic Log Splitter (A64127)
3pt Hydraulic Log...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
Brake Drums (A62613)
