Hydraulic squeel under heavy load
/ Hydraulic squeel under heavy load #1
ParkerFly
Bronze Member
I have a piece of equipment that's homemade and recently I've started having a problem with the hydraulic system. Under a heavy load or when a cylinder maxes out, it has started loudly squealing. It used to be pretty much quiet. I thought it might be the pressure relief and changed it, but it made no noticeable difference. I tightened the belt and keep the filters changed, but nothing has helped. Can someone point me to what might be going wrong? It worked for a few years just fine until recently. It's a pretty basic system: open center, 20 gpm rexroth pump with a clutch that flows through a series of valves that operate several cylinders and a hydraulic motor. Thanks,
Justin
/ Hydraulic squeel under heavy load #2
Add a hyd gauge to the system and see if the noise develops when you max out the cyl or stall the hyd motor.
I'm working on getting a gauge and getting it plumbed in. I can tell you it definitely develops with either maxing out a cylinder or stalling the hydraulic motor. I don't even have to stall the motor, just rev the engine up to speed the motor up and you can hear it start to squeal. If it stalls altogether (it or a cylinder) it is a deafening squeal. Could it be the pump itself? Or the clutch on the pump? I thought about changing the belt to see if maybe its dried out and causing it to slip even though its very tight. I have a spare pump but don't want to just start throwing parts at it. I forgot to mention earlier there's a priority valve in the system to send fluid to the steering. Not sure if it matters or not. Thanks again,
Justin
/ Hydraulic squeel under heavy load #4
Beltdriven..........Whats the shape of the pulley ?New pulley = v shape.........old pulley = u shape.........u shape no driving !
2022 John Deere 612R Sprayer (A63111)
2022 John Deere...
1080 (A64280)
1080 (A64280)
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
Caterpillar Lift Truck Parts and Service Manuals (A63117)
Caterpillar Lift...
2019 John Deere R-4038 (A63688)
2019 John Deere...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
