Hydraulic squeal, leaking steering column, hot oil; what's happening?
   / Hydraulic squeal, leaking steering column, hot oil; what's happening? #1
Sun Treader
Western Virginia
Case IH 495
Case 495, 50hp utility tractor. I have some issues developing with the hydraulics.
There is a loud squeal. It sounds somewhat like a slipping belt but is definitely related to the hydraulics. If I move the loader around a bit or vary the engine RPM the squeal will stop for a bit.
The oil is getting very hot. Working on the driveway after about an hour of dragging the box blade up and down the oil reservoir in the transmission hump between the floor boards is far too hot to touch.
Using the loader to move a bunch of dirt the other day right as I had finished up and parked oil started to leak from the top of the steering cylinder, coming out where the steering column enters the bodywork. Working on the driveway with the box blade and loader today there was some minor leaking from the top of the steering column, the oil was getting hot again, and the squeal isn't going away.
Oil levels are fine, filters are changed on schedule. I'm guessing something involving a relief valve or the pump? I'm not even sure where to start diagnosing the problem, so any help would be great!
   / Hydraulic squeal, leaking steering column, hot oil; what's happening? #2
I would start by disconnecting and reconnecting any quick coupling.
It sounds like you have one not fully seated and it is restricting oil flow and thus tripping the relief valve and building up heat.
Dave M7040
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2011 GMC Savana 10FT Box Van (A51692)
2011 GMC Savana...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A51694)
2008 Nautica...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
