Hi I am new,
I guess im trying to reinvent the wheel. I recently came across a rolling snowmobile chassis with most drive components removed. My plan is to re power it with a four stroke gasoline engine connected to a hydraulic pump which is connected to a hydraulic motor connected to the jack-shaft which runs into the sealed chain-case this turns the track. I am pretty good at mechanics and fabrication but i don't know much about hydraulics.
The use of the snowmobile would mainly be for off trail utility applications, such as hauling fire wood, dragging a skid, etc If possible and practical I would like to install a quick connect system off the pump for powering things such as a log splitter etc.
Possible issues I can think of are
Power, how big of a pump and motor do I need? Im thinking of going with a variable speed gear pump which increases and decreases flow with engine RPM. The pump would power a hydraulic motor that would smoothly engage and disengage at a certain flow of fluid from the pump are there such things?, The hydraulic motor would also need a valve in order to put the snowmobile in reverse. Are there decent pump and motor setups out there that would fit this application? Speed is sort of an issue also could I get good power and still run the sled at 40 MPH with a setup like this?
cost is another concern to re-power the sled with all new OEM components would cost around 2-3k.
Has anyone here tried something like this?
Thank you for reading, questions, along with any and all input is greatly appreciated.
Jeff
Jeff
