Hydraulic snowmobile
/ Hydraulic snowmobile #1
jjeff
Super Member
MI
kubota l2850, kubota l4150
Hi I am new,
I guess im trying to reinvent the wheel. I recently came across a rolling snowmobile chassis with most drive components removed. My plan is to re power it with a four stroke gasoline engine connected to a hydraulic pump which is connected to a hydraulic motor connected to the jack-shaft which runs into the sealed chain-case this turns the track. I am pretty good at mechanics and fabrication but i don't know much about hydraulics.
The use of the snowmobile would mainly be for off trail utility applications, such as hauling fire wood, dragging a skid, etc If possible and practical I would like to install a quick connect system off the pump for powering things such as a log splitter etc.
Possible issues I can think of are
Power, how big of a pump and motor do I need? Im thinking of going with a variable speed gear pump which increases and decreases flow with engine RPM. The pump would power a hydraulic motor that would smoothly engage and disengage at a certain flow of fluid from the pump are there such things?, The hydraulic motor would also need a valve in order to put the snowmobile in reverse. Are there decent pump and motor setups out there that would fit this application? Speed is sort of an issue also could I get good power and still run the sled at 40 MPH with a setup like this?
cost is another concern to re-power the sled with all new OEM components would cost around 2-3k.
Has anyone here tried something like this?
Thank you for reading, questions, along with any and all input is greatly appreciated.
Jeff
/ Hydraulic snowmobile #2
Hi I am new,
Jeff
Unless you do this, just for some fun shop hours, this will be the best advice you ever will get on this project....
STOP ANY INVESTMENTS INTO THIS PROJECT NOW!!!
A FEW REASONS....!
***Compared to a regular snowmobile, you will need, at least, twice size motor/engine because of all power losses in the hydraulics and all the extra 250-500lbs of weight you will be adding in hydraulic components and fluid...
***It will cost you much more than buying a better used snowmobile...
***You will need great cellphone coverage in the area you are going to operate this hydraulic-snowmobile, because it will become so heavy, so wont be able to handle a "stuck situation" on your own....
There is a reason why no-one have tried to invent this "wheel for real"....the reason is "common sense".....nothing can beat mechanic belt driven clutch transmission in efficiency and simplicity...
I think there was a project in the 70's, where a torque converter was used....
Hi, Thanks for the input, It is definately a fun project only thats why I mess around with ideas like this, I seem to learn a lot more about things by trial and error and enjoy coming up with new ways to solve problems. I already have 4 operating reliable snowmobiles and just want to try something different. I guess I was just trying to think outside the box. At one time I owned a evinrude snowmobile with a rotary cumbustion engine it had by far the most torque and best fuel economy out of most 2 stroke sleds I owned. yet rotary cumbustion engines never took off. What confuses me is the fact a skidsteer for example weighs 5k+ is powered by a smaller , diesel engine 30-90 hp and uses both gear and varible displacement pumps for not only traveling but moving a ton of dirt. All I want to do is use a single pump hooked to a hydraulic motor to move a 500 lb snowmobile along and have remotes for running stuff like a log splitter. As for getting Stuck I guess ill mount a hydraulic winch on it LOL. For now I will study up on hydraulic systems.
Thanks Again for the input
Jeff
/ Hydraulic snowmobile #4
Jeff
Just for the fun of a hydraulic project, I'd love to see your maiden voyage on a video clip...
I was involved in a hydraulic snowmobile project once (around 1990), but that was a power test bench for snowmobiles (power on the track mat)....we had to skip the hydraulics and go mechanic....there was just to many loose ends in hydraulics, to worry about, all power had to go into heat, and it screwed up viscosity on fluid...bench worked great, but we had to stick with our own horse power units LOL....We used it successfully for comparing engine power between racing machines that my buddy built...one machine had a turbo charger on a 2 cyl two cycle engine....added some good extra horses that way...
Maybe ill be on funniest home videos LOL ....It problaby wont be done for a while If I can make it feasible. Im pretty sure you can find oil coolers to deal with heat issues or maybe even modify the exchangers on the tunnel providing they will hold up to high pressure. Fortunately Im already ahead cause I got the rolling chassis for free. Anyone know of a website, mathematical formula, or reccomendation to help me find wht size, and type of pump and motor are needed and what size gas engine I need to run the pump?
Thanks again
Jeff
/ Hydraulic snowmobile #6
JJeff, to put things in perspective, I am building a hydraulic tracked vehicle and I am shooting for a top speed of 6-8 MPH (27hp 4 stroke 2cyl). For the kind of speed you are looking for, you won't get the rpm range out of a hydraulic motor. You will need some kind of fancy transmission to channel a hi-torque hydraulic motor spining at 300 RPM. Also remember that for example the 40 horse diesel on my farm tractor puts out about 240 ft lbs of torque, compared to a 100 horse snow machine engine putting out 75ft lbs of torque. I believe you are looking at needing to retain the centrifugal clutch, take a hi-torque hydraulic motor (maybe 20hp motor)through a 10:1 step up gear box and then find at least a 30 gpm pump powered off a 50 hp engine. Or you could as other suggest, just hook a motor up to the snowmachine clutch and forget the hydraulics. Hydraulics equal slow. Start by looking at some of the hydraulic stuff at the Surplus Center. Check on the motor specs, IE Max RPM and torque and max GPM. Figure on having a 4 stroke engine 15HP for every 10 GPM flow. Consider that you will need 200lbs of hydraulic fluid and reservior, filters, coolers, motor spool valve, pressure valves, gas engine, tank, hoses. I am guessing $3000-5,000.
/ Hydraulic snowmobile #7
Very interesting project. As mentioned a couple times already weight is a big problem.
Snowmobiles are very clever in their light weight engineering. Replacing the 2 stroke engine and CVT/clutch defeats most of that.
Figure out how much the finished project will weigh and then practice lifting half that weight to chest height before you venture off trail into deep snow.
Snowmobiles work well because the CVT is tuned to provide optimum torque for the situation. You would have to manually accomplish this with valves, not an easy task especially if your goal is 40MPH. Take some time to consider how a snowmobile "gears" down under heavy load while keeping RPM high. It's a critical characteristic when the going gets tough. Fail and you will be back to lifting the machine out of the hole you dug.
Good luck. Post video.
/ Hydraulic snowmobile #8
I think it would be a great project and would work fine if your donated sled was an alpine, could have the winch then too.
Rick
/ Hydraulic snowmobile #9
http://thekneeslider.com/archives/2008/02/05/hydrostatic-2wd-motorcycle-raccoon-update/
Welcome to Hydraulic Innovations
Check those out or Google Hydrostatic motorcycle to give you some idea.
I think it would work for low speed and high traction. Look for used zero turn lawnmower for donor hydraulic parts. Also look what parts are in zero turn mowers to make it move.
In essence you need reversible variable delivery pump and simple hydraulic motor. All powered by an engine with speed governor.
I would say go for it. If you do post pics of the process. We love pictures.
/ Hydraulic snowmobile #10
I've considered building a twin track sled from two junkers for grooming my personal trails. Hydrostatic would be good in that application for turning individual tracks under load & not needing more than about 15 mph. Could also power a hydraulic winch or grooming drag. Doubt it would be very practical for a general riding sled.
If you build anything please post, pass or fail. Sometimes more ultimately comes from failure than success. MikeD74t
/ Hydraulic snowmobile #11
In such a case, you might be better with 2 tracks and no skis as it would probably be hard to turn a two tracked machine with just skis.
Aaron Z
/ Hydraulic snowmobile #12
Aaron Z
It is indeed; if you've never tried riding a Ski-Doo Alpine(twin tracks/single ski)it's da-- near impossible
/ Hydraulic snowmobile #13
Aaron Z
You need double variable delivery pump and two motors and steer it like skid steer or zero turn mower. For decent pulling power at 15 mph it would require minimum 40 HP IMHO. That is based on observation of my 30HP HST tractor.
/ Hydraulic snowmobile #14
In such a case, you might be better with 2 tracks and no skis as it would probably be hard to turn a two tracked machine with just skis. Aaron Z
I've run Ski-Doo Alpines (twin track -single ski) and Bombardier groomers, the extremes of design. My idea, still in concept phase, is to use two chassis with two tracks and two skis, 1/2 way outboard of center on each track. I'll sit centered on & between the chassis as will the motor. The single ski Alpines are tough to steer in new snow & snowmobile tracks are too short & narrow to use without skis. Our club had a 2400 lb "Bombi" that wouldn't steer well in over 12" on snow towing a drag so a smaller machine would likely be much worse. The best answer to that problem was a hydraulic pivot on the drag hitch like a snowplow angle mechanism which caused the drag to stay centered in the tracks path on turns. I'm thinking the skis will help support the engine/drivetrain & provide longitudinal balance as well. The combination of steerable skis and individually driven tracks might work ok & hydraulic motors would be good for the track drives. Hydraulics would also allow the engine/pump/reservoir to be behind the operator which I hadn't thought of before. May never happen, if it does I'll post pass or fail. MikeD74T
/ Hydraulic snowmobile #15
It might be interesting to tie the drive for the tracks into the ski steering. Then when you cranked the steering over to one side it, it would slow the inner track.
That might work to make the machine more manageable.
Aaron Z
/ Hydraulic snowmobile #16
A yoke & wheel system similar to a light aircraft could be tied to both the skis & porportioning valves for each track would vary the track speeds coordinating with the degree of ski turn as well tying in a reversing valve. Steering, braking, forward, & reverse all in one system. Probably best to steer hydraulically as well. Makes hydraulics sound even better. Plumbing's getting expensive though. :D MikeD74T
Hi Guys thanks for all the input and encouragement, Ive posted a few pictures of the donor chassis, Unfortunately its not a alpine. Currently its weight is around 300 lbs gutted, A normal sled weighs between 5-700 lbs Ideally id like to find a used 20-30 hp Kohler or Briggs V twin four stroke, preferably a 10gpm pump maybe slightly more or less. I believe from what I have studied so far i need a reservoir equal to the amount of fluid it pumps per minute correct? I noticed there are two speed wheel motors does anyone have experience with these? My plan is to keep the jack shaft and chain case which currently has a 24 tooth top drive gear (from the jack-shaft into a 44 tooth driven gear which spins a 9 cog final drive (2.52 pitch) Turning a 121 " track (If my idea works im putting in a 136" track) ideally id like to keep the chain-case and jack shaft set up as it seems easier and cheaper to change gear ratios instead of hydraulic components in order to get ideal speed and power. The fabrication for mounting the components should be fairly easy as there is quite a bit of room under the hood with the old drive system removed. For me its a matter of finding the right components that will work.In any case keep the suggestions coming and ill keep you posted. Thanks again Jeff
/ Hydraulic snowmobile #18
I have a Power Trac PT425 tractor. It is hydraulically articulated and hydraulically driven. It is powered by a 25HP Kohler engine. The engine spins a variable volume pump. That pump provides power to 4 wheel motors. There are two more pumps that are also spun by the engine. One is a 4 GPM pump that provides power to the steering rams and front end loader arms and a quick attach system for the implements and power angle of plows, opening grapples, etc... the second pump is an 8 GPM PTO pump to power mowers, brush cutters, power brooms, trenchers, etc...
The problem you are going to run into by varying the speed of the motor to control ground speed is that you cannot stop and start the unit smoothly. You should use a variable volume pump to drive your motor. To get the best performance, you will have to run the motor at a constant 3600 RPM. If you run it slower, you will not get any torque out of the hydraulic pump. Also, those types of engines are made to run at that 3600 RPM speed for proper cooling with their fan that is driven off the crankshaft. Too low of RPMs with too big of a load will overheat the engine.
Secondly, there is no transmission, therefore, there is no gearing. This means you have to pick a hydraulic motor that will give you either low speed and high torque or high speed and low torque or somewhere in the middle, which is moderate speed and moderate torque.
The top speed on my tractor is 8MPH. It has good transport speed across the lawn. It will go up a 25 degree slope if there is no load. If I turn on the mower, I cannot drive up a 25 degree slope. It sucks too much power for the mower. Likewise, if I pull a log up a hill, it has noticeably less power to pull me up a hill.
Some Power Trac owners that want more torque to go up hills with a load swap out the wheel motors for larger displacement motors. This give much greater torque at the wheels, but cuts the top speed proportionally. IE, if you double the size of the wheel motors, you cut the top speed in half.
My guess is that if you want to pull the weight of the machine and, say, a sled with some firewood on it over varying terrain, your top speed will not be much over 5MPH.
If you change the variable volume pump and motor to get 40MPH top speed, my guess is the thing will not have enough torque to move itself off of a dead stop.
Besides the added weight of the engine, hydraulic pump, hydraulic motor and steel mounts for all of that, don't forget you will need at least a 10 gallon hydraulic tank and 10 gallons of hydraulic fluid.
I hate to be a downer, but I really don't think it will work as spec'd.
/ Hydraulic snowmobile #19
:thumbsup:
MossRoad, I am impressed of how well you nailed down the hydrostatic "vital" limitations....Great experiences from the engine parts too....learned some there....:thumbsup: Thx!!
There is a possibility to get a variable motor to increase the range of speed. But that will also require an advanced pilot control system, to synchronize pump and motor.$$$$!!!
In ALL hydrostatic transmissions, even with Variable pumps AND variable motors, it is impossible to combine high output torque with high out put speed, with out using over sized horse power engines. Mechanical gearing is also definitely necessary to give provide a wider range of torque-speed operation.
A hydrostatic transmission is almost to be compared with a friction clutch in a mechanical transmission, or a torque converter in an automatic transmission. VERY narrow speed-torque range, as a part of mechanical gear transmission.
Variable pumps are volumetric in-efficient at low speed and low displacement, and mechanically in-efficient (friction) at high displacement.
Same with variable motors, volumetric in-efficient at low speed mechanically in-efficient (friction) at low displacement.
This makes the whole deal a big power loss, if poorly designed (wide range of speed-torque operation)....
BTW, hydrostatic transmissions are most useful on machinery that operates other implements, during motion, like lawn movers, asphalt spreaders, truck size mountain snow blowers, etc, because it is possible to travel very slow, with the high engine rpm's, that are needed secure high power for the implement. And also great for equipment that require exact speed and motion control, when gravity is in play!! A hydrostatic system, provides the same brake force as pull force. Great for logging equipment in difficult and sloping terrain.
I know about a guy in Israel that specializes on smaller hydrostatic designs, even bicycles....Give me a PM, and I'll "leak" his name to you! He is busy but very helpful too......
/ Hydraulic snowmobile #20
A few more observations...
A typical Kohler 25HP engine is about 44 cubic inches displacement, or, a little over 700 CCs. They run at 3600 RPM.
I had a Yamaha RD400 twin cylinder 2 stroke motor cycle that was 396 CCs, or about 25 cubic inches. Very similar to snowmobile engines.
The motorcycle would propel me down the quarter mile 0 to 118 MPH in 11.9 seconds.
I also had an old Ski Doo TNT 440 that would also do 100 in the blink of an eye. Never timed it, but not too many folks passed me. :laughing:
My point is...
I don't think I could remove the engine from either of those machines, install a Kohler, a hydraulic pump, a hydraulic motor, a 10 gallon hydraulic tank, 10 gallons of hydraulic fluid, etc... and get even 1/4 of that performance.
What you are going to end up with is a tracked tractor, which may be exactly what you are after. But to have any amount of torque for pulling any amount of load, you will have to sacrifice speed significantly.
If all you are investing is your time, for a learning project, then go for it. But if you are seriously going to reinvent the wheel, and have to spend money on the project, I think you should think long and hard before proceeding.
Good luck and best wishes. :thumbsup: :)
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2021 PC210L Komatsu Hydraulic Excavator (A64553)
2021 PC210L...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
