MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,680
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
XCAT said:Brian,
We had issues trying to fit a longer ram in the area we had, 4 stroke was the best to allow enough up travel. If I used say a 8 stroke ram I would not be able to lift the rh arm higher than the left due to dead area of the cylinder. And my main aim was to be able to lift each end of out grader blade the same amount off the ground from horizontal position and I can do that as the blade pivots from the left arm. Secondly when grading drains I tend to always dig on the rh side so this is why I only have limited up travel on the rod, but it gives me lots of down travel to get deep drain / channel. I also have three positions I can set the lower fork on so if any time I require a different task I can change the amount of up or down. But again our main problem was getting a cylinder to fit within the limits of this machine, a point I should have said in my earlier post. Hope this helps.
Cheers
xcat
xcat, I was thinking that you might of had a 6" stroke and it seemed odd to have 1 and 1/2" -- 2" of ram out when level, that's all. But even that would have made sense now knowing more what your main usage is. Hey, one other question, you don't have dpocvs, does your hydraulic side link wonder? Or have you not been able to use it enough yet to tell?
