Hydraulic releave valve
/ Hydraulic releave valve #1
BobQ
Conn
I have a 4720, is there a releave valve on the tractor hydralic system? if so where is it located and what should it be set at? I would imagine it would be set higher than your loader or back hoe releave valve?
Thanks Bob
I ment relief valve! But I can't find a way to change it?
Thanks Bob
/ Hydraulic releave valve #3
There is a relief valve under a cap at the backhoe valvebody but they are preset by Ameriquip, If you go up a few hundred PSI you can end up tripping off other Relief valves in the system like the loaders and the steering/hitch lift circuit of the tractor . On all compact backhoes the curl of the bucket is where most of your digging force is. Good luck
1998 Toro Groundsmaster 223D 52in. Commerical Riding Mower (A64194)
1998 Toro...
2016 Ford F-250 Pickup Truck (A64556)
2016 Ford F-250...
2018 Nissan Pathfinder SUV (A64557)
2018 Nissan...
213089 (A64276)
213089 (A64276)
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
