Hydraulic releave valve
/ Hydraulic releave valve #1
BobQ
Conn
I have a 4720, is there a releave valve on the tractor hydralic system? if so where is it located and what should it be set at? I would imagine it would be set higher than your loader or back hoe releave valve?
Thanks Bob
I ment relief valve! But I can't find a way to change it?
Thanks Bob
/ Hydraulic releave valve #3
There is a relief valve under a cap at the backhoe valvebody but they are preset by Ameriquip, If you go up a few hundred PSI you can end up tripping off other Relief valves in the system like the loaders and the steering/hitch lift circuit of the tractor . On all compact backhoes the curl of the bucket is where most of your digging force is. Good luck
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2015 Ford F-350...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2007 Chevrolet C6500 Landscape Dump Truck (A59230)
2007 Chevrolet...
2013 Ford F-150 Crew Cab Pickup Truck (A59230)
2013 Ford F-150...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
