hydraulic questions help
/ hydraulic questions help #1
workinallthetime
Veteran Member
Tulsa, ok
L45 TLB, ZD326P
ok i own a b3030 with a fel and bh, since i have a bh does that mean i have "power beyond" ?
/ hydraulic questions help #2
Yes. You have the auxiliary hydraulic block on the right side of the tractor below the FEL valve block and in front of the brake pedals. The front port is high pressure to the FEL, the FEL's PBY port hose runs back to one of the QD's for your BH... the other QD is from the BH back into the PBY port in the hydraulic block.
Worksaver 3 Point Post Hole Digger (A65640)
Worksaver 3 Point...
Great Plains 73290DH (A64126)
Great Plains...
2012 EXAOS 130BBL (A65643)
2012 EXAOS 130BBL...
2000 Volvo Semi (A66285)
2000 Volvo Semi...
2016 BOBCAT E35I MINI EXCAVATOR (A62613)
2016 BOBCAT E35I...
Used 20' Container (A62679)
Used 20' Container...
