Hydraulic question?
   / Hydraulic question? #1
Heavyduty
What would happen if a hyd motor on a rotary mower, that was being powered by a pto driven 540 pump, was changed by being powered by a 1000 pto pump? :confused2:
   / Hydraulic question? #2
Nothing unless GPM delivery went up or down. In which case motor speed would change. -- If its the same pump you are turning faster it would near double [1000/540]
motor speed in comparison to the lower PTO speed.
larry
motor speed over the lower PTO speed.
larry
Thanks for the reply. I have two pieces of equipment, they are same but one is has a 540 pump driven by my tractors pto and the other has a 1000 pump. I was seeing if the motors could be swapped out if need be.:D
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2022 Spartan RZHD Zero Turn Mower (A53117)
2022 Spartan RZHD...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2011 Kenworth T300 Jerr-Dan 21WSRB Rollback Truck (A52377)
2011 Kenworth T300...
