Sep 28, 2015 / Hydraulic question on a Ford 3000 with 720 Loader Thread Starter #11 OP N NHred New member Joined Sep 21, 2015 Messages 5 Location New Ipswich, NH Tractor Ford 3000 The hydraulic specs said it holds 5.25 gallons. I guessed I did not loose all the fluid so I put 4 gallons in only. I did not see anywhere where it said how to check if the fluid is topped off.
Sep 28, 2015 / Hydraulic question on a Ford 3000 with 720 Loader Thread Starter #12 OP N NHred New member Joined Sep 21, 2015 Messages 5 Location New Ipswich, NH Tractor Ford 3000 See my reply to Japody, any idea how to check the fluid level?
Sep 28, 2015 / Hydraulic question on a Ford 3000 with 720 Loader #13 Soundguy Old Timer Joined Mar 11, 2002 Messages 51,575 Location Central florida Tractor RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC level check plug. A little overfill is ok, makes up for using large SA hyds.. but too much overfill will lead to pto and axle seal leaks.
