hydraulic pump
/ hydraulic pump #1
riley19d
CAMERON, NC/FT.BRAGG, NC
2005 jinma 454 le
putting a new pump on tomorrow, just wanted to get some recommendations on ensuring the pump is properly primed and fluid is full, lost all fluid when the pump broke. thanks
jinma 454
/ hydraulic pump #2
jinma 454
i used compressed air into the vent w the suction line cracked slightly
/ hydraulic pump #3
Well with the sump higher than the pump, it's gravity feed when the pump's not turning. Install your pump normally, refill the sump, but don't put the ven/fill plug back on just yet. That will permit better venting to get fluid to the pump. Then loosen the supply line at the pump until gravity drains fluid from the sump and through the supply line. When it starts running out at the pump, tighten the supply line back up.
Then loosen the pump's output line slightly, and turn the motor over by hand. That will draw fluid THROUGH the pump so the engine isn't starting a dry pump. When you get fluid out the output port, tighten that up too. At that point you should be able to start the engine and let horsepower push the rest of the air out of the system. Don't forget to replace the vent/fill plug on the sump.
//greg//
2013 Ford F-250 Pickup Truck (A61568)
2013 Ford F-250...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 TOYOTA TUNDRA(INOPERABLE) (A60736)
2017 TOYOTA...
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
