Hydraulic pump shim
/ Hydraulic pump shim #1
Majortomsdz
Ct1021
Anyone know of a kit for a ct1021 or at least what pump is used/diagram.
Want to check current pressure and possibly increase a tad.
/ Hydraulic pump shim #3
For the CT1021, the pump is likely a gear pump, but exact specs might vary depending on the year/model. You can grab a pressure gauge kit online or from your local hydraulics shop to check it. If you’re thinking about cranking up the pressure, just remember—more isn’t always better unless you like fixing blown seals. 😉 A service manual or diagram from your dealer should have the adjustment specs. Good luck dialing it in!
INTERNATIONAL 674 TRACTOR (A64276)
INTERNATIONAL 674...
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
PALLET OF APPROX (12) 2" X 6" X 55 1/2" TUBING (A64280)
PALLET OF APPROX...
2020 Deere 50G (A64119)
2020 Deere 50G...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
Case Titan 3530 (A63688)
Case Titan 3530...
