Adjusting low hydraulic pressure CT2025
   / Adjusting low hydraulic pressure CT2025 #1
cavediver usa
Bobcat CT2025 HST
My hydraulic pressure is 2300 the spec is 2600. Does anyone know where the adjustment is on the CT2025.
   / Adjusting low hydraulic pressure CT2025 #2
These pages are out of the CT225, ct230, ct235 manual. Guessing yours will be similar. MIght help , might not.
  • bobcat 20-20-1.pdf
  • bobcat 20-20-2.pdf
  • Bobcat 20-20-3.pdf
  • bobcat 20-20-4.pdf
  • bobcat 20-20-5.pdf
  • bobcat 20-20-6.pdf
   / Adjusting low hydraulic pressure CT2025 #3
Its at the joystick valve, under plastic cover
   / Adjusting low hydraulic pressure CT2025 #4
You might want to check near the hydraulic pump—there's usually an adjustment screw there. A service manual could help pinpoint it exactly on the CT2025.
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
New/Unused 7ft Stainless Steel Work Bench with 20 Drawers (A54865)
New/Unused 7ft...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
