Adjusting low hydraulic pressure CT2025
   / Adjusting low hydraulic pressure CT2025 #1
cavediver usa
Bobcat CT2025 HST
My hydraulic pressure is 2300 the spec is 2600. Does anyone know where the adjustment is on the CT2025.
   / Adjusting low hydraulic pressure CT2025 #2
These pages are out of the CT225, ct230, ct235 manual. Guessing yours will be similar. MIght help , might not.
  • bobcat 20-20-1.pdf
  • bobcat 20-20-2.pdf
  • Bobcat 20-20-3.pdf
  • bobcat 20-20-4.pdf
  • bobcat 20-20-5.pdf
  • bobcat 20-20-6.pdf
   / Adjusting low hydraulic pressure CT2025 #3
Its at the joystick valve, under plastic cover
   / Adjusting low hydraulic pressure CT2025 #4
You might want to check near the hydraulic pump—there's usually an adjustment screw there. A service manual could help pinpoint it exactly on the CT2025.
2842 (A54756)
2842 (A54756)
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A55851)
Dvorak Model 3072A...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
2023 PETERBILT 567 VOLUMETRIC CONCRETE (A55745)
2023 PETERBILT 567...
