Hydraulic pump on farmpro 2425
/ Hydraulic pump on farmpro 2425 #1
dalestractor
Farmpro 2425
Recently I had issues with my hydraulic pump so I pulled it and got a rebuild kit,(some seals and orings ),but when I put them in the seals are thicker than ones that were in it when you tighten the two bolts adasnt from each other you can't turn the shaft with a wrench, any idea's?
/ Hydraulic pump on farmpro 2425 #2
Are the seals you talking the orings or quadrings for the body if
You have old ones go to a seal place a match them up or take seal kit back
/ Hydraulic pump on farmpro 2425 #3
Also turning pump motor and tighten a little bit at time so it does not bind do nkt
Over torque
Quadrings
/ Hydraulic pump on farmpro 2425 #5
So you can use orings in some cases but you still need to not have them to thick. Did you get this pump working yet?
