Hydraulic pump ID
/ Hydraulic pump ID #1
Arkhermit
Compton, Arkansas
2350 JD, 820 JD, 3600 Ford
I have a two section pump,it is Cross brand and has 2479 stamped in the mounting flange. I have emailed the MGR but no responce. The inlets are 1" I looked on one site at a pump that looked about like this one and it said 40 gpm per section. I am building a firewood processor and need to run Hyd saw and two motors for convyers plus splitter.
/ Hydraulic pump ID
Well i bombed on this deal I guess. I will just build it and see if it works. To clarify I didn't ask any questions and the inlets are actually 1 1/2". I wanted to find out some info on this pump and then a motor. BUT ?
/ Hydraulic pump ID #4
Call Surplus Center with the brand and number and theywill be able to help you.
BillK
/ Hydraulic pump ID
I emailed surplus center with the info. They said what I thought was a motor was probably a pump, needed more info, sent it, haven't heard anything for several days. Didn't have a clue about the Cross two section pump.
Auger Cart (A65640)
Auger Cart (A65640)
CATERPILLAR 314EL CR EXCAVATOR (A64277)
CATERPILLAR 314EL...
(2) 4' Steel Wheels (A66408)
(2) 4' Steel...
2005 Chevrolet Silverado Service Truck, VIN # 1GCJK33245F911286 (A65563)
2005 Chevrolet...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
