Hydraulic problem?
/ Hydraulic problem? #1
idaho04
There is something wrong with the hydraulics on my F1900. It may or may not be related to the cold spell we went through, 5-20F during the last 10 days. It is in the 20s now but no improvement. After I start my tractor the loader and 3pt will work for about 1 minute but then it stops working. The loader and 3pt arms will go down but will not go up. It seems that the pump does not labor at all. First I thought the oil is too cold but I used to plow snow and work in the winters before. Any advise what should I look at?
/ Hydraulic problem? #2
Possibly water in your hydraulic system and it is freezing up. That would be my first thought.
Ben
When the same thing happened once last year I changed the oil last summer as I was suspecting the same thing. Some questions remain: did I change all the oil as I just drained it (there could have remained plenty in the cylinders), could moisture get in again, how often do I have to change the hydraulic oil, there is a lot of it in there.
/ Hydraulic problem? #4
You probably have a plugged suction screen. The hydraulics working for a short time then quitting is the tip-off. Drain the oil and clean the screen which is located where the suction tube enters the rear frame; held on by 4 bolts. Do it before you trash your pump.
It could make sense what you are saying. I am not sure where I will find the screen but I'll look in the tractor book and see. My oil is both hydraulic and transmission, a lot of it, in the xmission box.
It does, it has always sit in the rain.
/ Hydraulic problem? #8
<font color="blue"> Possibly water in your hydraulic system and it is freezing up. That would be my first thought. </font>
Idaho, this was my very first thought too. By "water in the hydraulic system", I don't mean a big puddle of pure water somewhere, like you might find in the bottom of a gas tank. I suspect that the hydraulic fluid has picked up water throughout all the fluid in the system, and I bet (my usual) $.05 that if you look at a sample of the fluid it will appear quite milky. Your same exact symptoms just happened to my log truck.
What I suggest you do is keep the machine in a heated place until you're sure it's all thawed out. Another $.05 says all the hydraulics will then work fine. Then change the hydraulic fluid and filter(s) and you should be good to go for the winter, with just the usual "morning sickness" to contend with.
I'll bet my last $.05 that the reason it's always been fine in previous winters is that the fluid had not yet picked up enough water to lower its gelling point.
As another poster said, take care of it right away before you hurt your pump, they hate cavitation (and water!). Ditto the rest of a hydraulic system, water and contaminants are murder on EXPENSIVE hydraulic components. Seals, rods, pumps, motors, spool valves, everything.
Lots of other fluids need to be changed WAY more often than they typically are. Funny how we wouldn't dream of missing an engine oil drain interval, but let some things go way over what the maintenance schedule calls for. Brake fluid (every two years at least - it REALLY absorbs water), antifreeze and gear oil come to mind. How many cars are there out there with brake fluid that hasn't been changed in 5-10 years? And think of all the poor, forgotten differentials out there, wearing out long before their time. /forums/images/graemlins/frown.gif
OK, there's my $.15 worth /forums/images/graemlins/laugh.gif
/ Hydraulic problem? #9
Drain a bit of the fluid out and see if it is milky. If so replace it. I have seen tractors that sit outside get enought water in them that the transmission freezes up and the tractor won't move.
The tractor oil might have to be above freezing , not sure what wet hydro fluid looks like below freezing though.
A tractor that sits outside can get water in the tranny from one of several seals leaking.
Ben
/ Hydraulic problem? #10
Follow the large tube back from the pump to the rear axle center section. The tube enters the screen's outer cover which is bolted and gasketed to the rear end housing. I am quite sure you will need to clean or replace the screen to get your hydraulics working properly. You will damage your pump if you run it for long like it is. A batch of oil is quite a bit cheaper than a batch of oil and a pump.
OK, today I drained the oil and took out the suction screen. Although I drained and replaced the h oil last summer, I noticed that the screen sits lower then the drain plug and I saw some thick milky oil there. When I was cleaning the screen with a toothbrush and diesel I noticed kind of white lint. After looking closer I think it looked like small frozen moisture crystals. Anyway the screen cleaned well and I was convinced I found the problem.
However when I put it together and tried it it it did not work. So I decided to look at the pump. To my surprise the pump is in great shape. No oil inside though. It seems to me that there must be a trick to suck the oil into the pump. I wonder if I should open the system somewhere on the output side to let the oil in the pump.
All right, all fixed and working.
Most of you were correct, thank for help. I changed the hydraulic oil couple of times but did not clean the screen. Oil trickled through the screen until it stopped completely in the freezing temperatures. The system was just air.
After I cleaned the screen the pump did not draw the oil into it. The instructions in my detailed shop book did not work. So I ran the tractor in idle and slowly loosened the output pipe connection at the pump. After few seconds fluid started gushing out. This took care of priming the pump. No it works.
I am happy, happy happy.
2015 Kenworth T680 (A64127)
2015 Kenworth T680...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A59914)
2019 FREIGHTLINER...
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
