Hydraulic problem
   / Hydraulic problem #1
J&R
2005 farmtrac 535
3point hitch comes up a few inches and stops then a few more inches and stops front End bucket doesn’t work at all. Filter has been changed and screen checked. Does anyone have any ideas. Is it the pump? any help would be appreciated.
   / Hydraulic problem #2
It COULD be the pump but it's unlikely. Check your hydraulic fluid level, it may be low. Also check for any loose or leaky connections. If you have quick disconnects on your hydraulic lines sometimes problems are solved by simply taking them apart and reconnecting them.
   / Hydraulic problem #3
JR
What make and model of tractor is this?
What were you doing prior to things stopped working?
Any new or unusual noises?
like roadworthy states check fluid level, for leaks, etc.
   / Hydraulic problem #4
Does the tractor have hydraulic remotes?
   / Hydraulic problem #5
Add more details, such as behavior and background. Pumps alone do not operate intermittently.
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2024 Scag V Ride XL (A51573)
2024 Scag V Ride...
2013 BOBCAT S630 (A52472)
2013 BOBCAT S630...
2023 John Deere 8R 280 MFWD Tractor (A53342)
2023 John Deere 8R...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
