Grapple Hydraulic problem
/ Hydraulic problem #1
Crescent
Brant, Ontario
BX25
I just put on a Landpride grapple on my BX25 with a 3rd function valve kit. The grapple opens and closes 2 to 3 times and then the hydraulics freeze. After some effort I remove the hydraulic lines - relieve the pressure from one of the lines - reconnect and again after 2 to 3 openings - it freezes.
/ Hydraulic problem #2
Which Land Pride Grapple? There are ten of them.
Which brand of third valve kit?
DO you mean the counterbalance valve??
Its possible that you have the hoses reversed,
actually its most likely the cause as the oil is only
supposed to flow through the third valve to the function
and then back to the tank.
Is your loader equipped the the single stick gimbal control
for the bucket tilt and loader raise and lower function?
You will probably be better off using the rear remotes if you have a free pair as the gimballed loader valves are not the greatest things to use for loader mounted attachments as these valves wear and the gimbal control springs weaken.
White Oak Boards (A65640)
White Oak Boards...
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
2021 UTILITY VS2DX 53X102 T/A DRY VAN TRAILER (A59914)
2021 UTILITY VS2DX...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
