Hydraulic pressure
   / Hydraulic pressure #1
Dranerb57
Bear, DE
Kubota L4330
I have a kubota L4330hst with a loader, what is the hydraulic pressure the tractor produces? Its flow is around 9.4 GPM
   / Hydraulic pressure #2
Welcome to TBN
Since no 4330 owners are coming around yet I'll give you a maybe answer. I am not sure about your specific tractor but from my limited experience all the L series machines I have seen were spec at a 2500 psi factory setting.
Thanks for the info, I called the local kubota service dealer, they just said under 3000 psi
   / Hydraulic pressure #5
I have a flyer from 2007 and I well look tomorrow and see if it's in it and get back with you tomorrow night.
Ok I'll try that site THANKS
Thanks, I just got on this site and you guys are great source of info!! I appreciate the help!!
   / Hydraulic pressure #9
Dranerb57,
The tractor will produce a pressure based on the load on the hyd system.
Relief pressure is set to relieve at a pressure below the pumps max pressure to protect the pump.
A 3000 psi hyd gage is highly recommend to monitor and trouble shoot the hyd system.
J.J. is the gage something I can get at the kubota dealer, graingers, TSC?
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2017 Nissan Frontier (A53422)
2017 Nissan...
2017 Nissan Titan SV Crew Cab Pickup Truck (A51692)
2017 Nissan Titan...
2013 Land Rover Range Rover Sport 4X4 SUV (A51694)
2013 Land Rover...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
Genie GTH-5519 (A50123)
Genie GTH-5519...
