Hydraulic pressure
/ Hydraulic pressure #1
Dranerb57
Bear, DE
Kubota L4330
I have a kubota L4330hst with a loader, what is the hydraulic pressure the tractor produces? Its flow is around 9.4 GPM
/ Hydraulic pressure #2
Welcome to TBN
Since no 4330 owners are coming around yet I'll give you a maybe answer. I am not sure about your specific tractor but from my limited experience all the L series machines I have seen were spec at a 2500 psi factory setting.
Thanks for the info, I called the local kubota service dealer, they just said under 3000 psi
/ Hydraulic pressure #5
I have a flyer from 2007 and I well look tomorrow and see if it's in it and get back with you tomorrow night.
Ok I'll try that site THANKS
Thanks, I just got on this site and you guys are great source of info!! I appreciate the help!!
/ Hydraulic pressure #9
Dranerb57,
The tractor will produce a pressure based on the load on the hyd system.
Relief pressure is set to relieve at a pressure below the pumps max pressure to protect the pump.
A 3000 psi hyd gage is highly recommend to monitor and trouble shoot the hyd system.
J.J. is the gage something I can get at the kubota dealer, graingers, TSC?
/ Hydraulic pressure #11
I got mine here: Bottom Mounted Pressure Gauges
Here is a picture of what I have. The gunk inside you see is glycerin. A vibration damper. Right now there is a male QD that fits a rear remote female QD on my tractor. Put on what ever fitting/hose you need for the measurement port you need to connect to. A short hose with a 1/4" male NPT is often handy.
I'll get to TSC this weekend appreciate your help
/ Hydraulic pressure #14
Ken's Bolt On Hooks sells them now too. It's a 0-5000psi liquid filled gauge with a 18 inch (or so) hose and an ISO 5675 male plug. It would save you the trouble of putting one together. I was a little over 40 bucks, and I got in a few days. He has a few different sizes, I'm guessing you have 1/2 inch quick couplers.
/ Hydraulic pressure #15
drener I got on from NAPA auto parts it was in stock $30.00 Grainger had one for $58.00. NaPA was also closer to me.
/ Hydraulic pressure #16
So J.J. I should have measured the psi with a load on the scoop to find something closer to the max?? I only had the scoop itself on the TPH @ the time.. & was 1700-1800 psi. (just 4 my own info) I am happy with the way it works..
the only complaint I have 4 the scoop is the lifting spindles are 30 inches apart and the ones on my mower & BBlade are 26/27 inches. I am going to have a shop move the scoops to about the same so settings can be left alone when changing implements.. @ 30 inches there is barely any room left between the tires..
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
Peterson Horizontal Grinder (A62613)
Peterson...
2011 CASCADIA 6X4 T/A DUMP TRUCK (A59914)
2011 CASCADIA 6X4...
UTILI TOUGH 48" RAKE (A64277)
UTILI TOUGH 48"...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
