Hydraulic piston
/ Hydraulic piston #1
gadi
ישראל
john deere
Hello everybody,
I am new at this forum and I have a question for the ones who can help:
I need to plan a hydraulic piston that is normally open.
I can not trust the operator to open the piston, so he will have only to close the piston by hand and it`s need to be open automaticly.
It need to be open after 30 seconds and after 10 seconds of delay.
Who can help me with a solution for that?
Thanks, Gadi
/ Hydraulic piston #2
:welcome: to TractorByNet!
When you say "hydraulic piston", do you mean hydraulic valve?
/ Hydraulic piston
View attachment 348353 View attachment 348354
Hi,
Thank you,
I am talking about the piston not the valve, but maybe the solution will be on the valve.
It`s a double side piston that connect the device to the frame when the piston is open, and diconnect when it`s closed.
I need that the piston, after using it, will go back to it`s open mode.
Hope you will understand me :)
Gadi
/ Hydraulic piston #5
Sounds like you need a electronic circuit and solenoid controlled relays...
Any chance you could post a picture of the machine this will be used on?
Edit, what do you mean by "open after 30 seconds and after 10 seconds of delay" Do you mean that it needs to stay open for 30 seconds then close, or???
Aaron Z
Blue Diamond Brush Cutter (A64126)
Blue Diamond Brush...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
2015 MGS GODWIN CD150M PORTABLE DRI-PRIME (A63276)
2015 MGS GODWIN...
Wolverine Quick Attach Brush Mower (A66408)
Wolverine Quick...
25' Flat Fold Cultivator (A66408)
25' Flat Fold...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
