Hydraulic part numbers
/ Hydraulic part numbers #1
JamesH
Paola, KS
JD 4300
As I work through adding remote SCV's to my 4300 can some one help me with some part numbers.
I am ordering a 3way Prince valve from Surplus center and there are a lot of options available. I believe I want a 9SV-3-X-BBB. SV type, 3 spools, Open center, all valves Open Center Spring return.
The valves will be for TNT and a grapple.
My setup will be very similar to jimgerken. Jim said he paid $280 for his valve and when I configure the one above I only come up with $232 so I am concerned I may be missing something.
Also, to be compatible with the other quick disconnects that JD uses, can some one describe exactly what they use now? So I can buy them someplace online and besides JD and not spend a ton of money on them. Jim mentions a Pioneer part but I am not having much luck finding them online yet. I will need nipples to go into the PB ports and then QD's coming off the valve itself.
I figure most of the other parts are fairly generic.
Thanks in advance.
/ Hydraulic part numbers #2
I don't want to hijack your thread but I have been looking for some bulkhead fittings to use to mount my QC with no luck. I am wanting to have npt on both sides with a bulkhead nut to mount it to a steel plate. any help would be greatly appreciated
I hope we can compile some good part numbers and sources and it will help a lot of people who are looking for this stuff.
For your QD's to bulkhead mount, look at the ones jimgerken used in his thread. They use a C-clip to capture it in the steel. Jim got them from a local dealer.
Maybe someone knows of another source for them.
/ Hydraulic part numbers #4
I've done a similar project and I've posted the part numbers here. The 1/4" QCs actually seem to work well with some cheaper Buyers part numbers, but finding the Parker QC (or something that worked with it) outside the dealer proved difficult at best. You can also look into swapping out all your QCs with more readily available versions. In the long run that may end up being cheaper but I'd get a price quote from the dealer before doing so.
/ Hydraulic part numbers #5
Pipe to pipe bulheads are hard to find. Discount hydraulics has 1/4 in steel . I have never found any bigger .I used to make my owm by welding a coupling in place. Now I use pipe to jic male bulkheads. QD on the pipe side and hose with a swivil jic on the other .
Ok JD QD. I have a NH. I bought a Fasse Diverter valve kit and it was made for a JD. What a #$%$. But The dealer made good on al the parts I needed to make it work. I have a handful of JD QD. The NH uses ISO A QD, 3/8 on the FEL and 1/2 on the remotes. The pump is 7.? gpm. 3/8 will pass 6 gpm and 1/2 will pass 10 gpm. Ok ISO A is nice everybody has them usually FPT. Since I had these JD QD I wanted to know what they were.
Co is FASTER they are on the net What appears to be the equal to 1/2 "
is FEMALE HNV38 12SAEFJ-0610
MALE HNV 38 12SAEM 061D
These do not mate with the 1/2 ISO A the thread on the back end is SAE 8.The Faster web site does not have the exact numbers
There may be some cross over equivalent but I have not looked hard
Don't know if I helped or not. There sure are a lot of QD out there.
The ISO A are really inexpensive $10 for F $ 5 for M at DHH, 600 series
Now you know about as much as I know.
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
Gravely Field Cultivator Attachment (A65640)
Gravely Field...
