Hydraulic oils
/ Hydraulic oils
No, I have never seen this pic. Did your machine come with this set up, or did you do some custom work here? My 1445 seat is above the oil filler cap. Is that the filtered cap you installed? I think I will get one of those for mine. Is that a standard 1/4 turn cap?
J.J.
/ Hydraulic oils #12
<font color="red"> No, I have never seen this pic. Did your machine come with this set up, or did you do some custom work here? My 1445 seat is above the oil filler cap. Is that the filtered cap you installed? I think I will get one of those for mine. Is that a standard 1/4 turn cap?
</font>
My seat is above the cap too. The original cover has been modified to accept the new cap. The old fitting was machined off and holes drilled and tapped to mount the new cap.
See a catalog picture of the new filler here.
Sedgewood
/ Hydraulic oils #13
<font color="red"> you were going to adjust your brakes some time back - how did that work out? Do they hold now?
</font>
I did a quick & dirty adjustment under some time pressure to get to a job. They hold much better, but need just a bit more. The manual tells how to adjust them, but doesn't say that you need to pump the pressure up pretty high for each individual wheel to make sure you get it adjusted with the clearance small enough. The tender bleeds down - which will be a problem for towing.
/ Hydraulic oils #14
<font color="red"> The manual tells how to adjust them, but doesn't say that you need to pump the pressure up pretty high for each individual wheel to make sure you get it adjusted with the clearance small enough </font>
Probably like a lot of things with PT documentation there are differences in what each of us received. My manual says to pump the pressure to 2000psi to adjust the brakes.
I installed a "service" switch that connects across the "out of seat sensor" on the tilt seat so that when I flip the switch to the closed position I can keep the tractor running when I am out of the seat.
While I haven't adjusted the brakes yet I think that if I start the tractor, activate the "service" switch I installed, and move the Brake tender to the operate position--then the pressure will be applied (and maintained) to the brakes so that they can be adjusted without manual pumping.
Again, I haven't actually done this process yet but I think it should work.
/ Hydraulic oils
You guys nust have a different brake sysem than the one on the older 1445's. I think mine is only used as a parking brake. My brake sys has a rotor with holes around the outer edge, so a sliding metal cylinder slides in the hole to lock the brakes. I don't think it will operate if the wheels are moving.
I am thinking of some kind of disk brake, like on a go-cart.
J.J.
/ Hydraulic oils #16
Bob: Having the engine running and the brake tender in "move" position certainly should hold the brakes open wide, so you can take the clearance down where it needs to be -- just don't bump the treadle. /forums/images/graemlins/tongue.gif
/ Hydraulic oils #17
J.J. On the newer 1845s, there is a "Brake Tender", which appears to be a separate product that PT or an afiliated company markets to others. Disc brakes are spring loaded, but disengaged by hydraulic power when the control lever is moved. When the engine shuts down, the lever is centered, or hydraulic pressure is lost, the brakes engage. I really like the system, but it does require tight adjustment for it to hold on a steep hill.
/ Hydraulic oils #18
<font color="red"> just don't bump the treadle. </font>
To do the adjustment safely the tractor should be up on supports so that the wheels are not touching the ground.
I don't know about you but I find it very difficult to manually pump the brake tender up to 2000 PSI because of the location of the pump handle. I think that if I ever had to tow I would adjust (release) the brakes rather than pump up the brake tender.
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
2011 Mercedes-Benz E-Class Sedan (A59231)
2011 Mercedes-Benz...
2021 ISUZU NPR (INOPERABLE) (A60736)
2021 ISUZU NPR...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
iDrive TDS-2010H...
