Generic wheel motors
/ Generic wheel motors #21
Thank you all for the help. Will look thru those threads.
/ Generic wheel motors #24
I am going to do my own rebuild this year on a leaky wheel motor. In my area there is an extensive wait for rebuild services and the price is almost equal to just buying new.
/ Generic wheel motors #25
Never having rebuilt a wheel motor, I don't know what is involved. My experience rebuilding cylinders has been mixed whether I rebuilt them or had them rebuilt at hydraulics shop. The last cylinder I tried to rebuild on my Terramite still leaked so I replaced it with a new one. The seals were so expensive and it was such a messy job that it was very disappointing to see the old cylinder keep leaking so I just bought a new one instead of making another attempt at repairing the old one.
I also had an expensive and disappointing repair on a Mahindra steering cylinder at a professional hydraulics shop.
This is just my long way of saying that I really understand wanting to find a generic wheel motor to avoid all the hassle and expense if that is possible.
/ Generic wheel motors #26
If it was slag, it was from when it was manufactured. Remaining welding splatter inside the tank is why I lean this way. I am the original owner of this machine. If my assessment is correct, it is pretty impressive the original pump made it ~ 2800 Hrs. Now have a magnet on the filter to try and capture metal.
Did not know they made such a thing as a bidirectional filter. That is good to know.
I own 5 Power Tracs. 422, 2422, 425, 2425, and 1430. I currently have 16 of these wheel motors in use, hence my thoughts on cost benefit.
The 425 is the only machine I bought new and is the one that eats wheel motors. I use this machine the most and as a result it has the highest priority on the maintenance schedule. The other 4 machines (ranging from 1999-2016) were bought used (3 commercial, 1 homeowner). From what I saw, only the 2425 had been maintained to the same level I have maintained my 425 since new. For the other machines, routine maintenance seems to have been taken as a suggestion. Rusted hydraulic filter, engine fire due to grass clipping build up, broken/welded wheel motor shaft from trying to move T barricades for a highway project, etc. As best I can tell, the used machines are still sporting mostly original wheel motors. The 425 seems to be a bit of a unicorn.
I appreciate the help
Sorry to hear about your repeated WM failures. I added a magnetic temp gauge to my main control valve and stop using the machine if the temp gets to high. With the wheel motors in a dedicated circuit, the oil temps may be even higher then the hyd reservoir (lift, steer circuits). There has to be a reason your motors are prematurely failing (in a sequence).
I do notice on my machines that the right front wheel is the first to spin which indicates to me it might be getting the high pressure oil first in series. That would mean it gets more stressed by having to start the machine in motion before the other motors are contributing.
/ Generic wheel motors #27
If the wheel is spinning because of loss of traction, does that put more pressure on the seals?
/ Generic wheel motors #29
If the wheel motors are in series where pressure goes to first motor and then output of first motor is input or pressure to second motor the first motor can see high pressure on both ports.
Example: first motor is on ice while second motor is on bare concrete. Second motor is now doing all the work so it will pressurize both the inlet and outlet ports of first motor. This is why was asking if these motors has case drain ports to prevent high pressure on shaft seals.
Heard back from the hydraulic shop. All the pressures tested good. As best we can tell, the older wheel motors failures were standard wear on the motor seals. As I said in earlier posts when I replaced the pump I also changed all the hydraulic oil and flushed the lines. I found metal in the tank. This most likely caused the wheel motor seals to fail.
The most recent failures are different. The needle bearing where the shaft meets the housing has been forced out. The shop has never seen a motor fail like this. I have three. All three have sauer danfoss tags on them. White was purchased by Danfoss in 2017. This is about the same time I changed the pump and flushed the hydraulic system. The hydraulic shop guys think there is some slight difference in the motor housing or needle bearing that is causing a looser fit than required.
Reached out to Danfoss. They say the only thing changed was the id tag. I asked if they changed vendors for the needle bearing and have not heard back yet. The engineer at White thought extreme side pressure is the culprit. This would make sense were it not for the number of machines/wheel motors I have in operation.
Danfoss had to recently let go of ownership of White because they bought Eaton. Monopoly laws. To get this machine back in operation, I had to buy a new non-generic motor. It has a White tag on it. Time will tell if it has the same problem.
Gave Power Trac a heads up. They haven't heard of this either. That makes a bit of sense because they had switched to the upgraded wheel motors prior to 2017. If the cause is a slight manufacturing defect, Power Trac's only exposure would be a limited number of parts sales.
Long story short, it is a head scratcher. The working theory above is based mostly on the timeline. Have not been able to identify a rock solid culprit.
/ Generic wheel motors #31
Does anyone have experience using generic versions of the white ce400 wheel motors used on the smaller PTs? Anyone ever mix name brand wheel motors with generic versions on the same machine and if so, did it cause any problems?
I ask because I have had zero luck with rebuilds over the years. Try to keep a spare on the shelf. The price I am finding for White branded wheel motors has doubled in the past few years (now ~ $900 + each). White has been bought then sold by Sauer Danfoss recently. Current lead times from White are measured in months/years. There is a company in FL selling a knockoff. Appears to be china made. Single wheel motor for $ 530 each. Buy 5 or more $ 390 each.
Thanks in advance
Do you have a link or contact info for the knockoffs? I've resealed/rebuilt all of my motors at least once, nd had to replace the axle shaft on one last year because of excessive wear where the needle bearings run on it. I think I got the last shaft that was still at the old price, and the new price is heartstopping. I don't remember the number, but it was a large percentage of the cost of a whole motor.
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
2014 FORD F-150 4X2 PICKUP TRUCK (A59908)
2014 FORD F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
Adams Under Truck Conveyor (A63118)
Adams Under Truck...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
