hydraulic oil
/ hydraulic oil #1
buckrrt
st paul ky
i have a jd 770. where do i check and fill the hydraulic oil at and what weight do i use? i dont have a manual.
/ hydraulic oil #2
There should be a dipstick at the rear of the machine. You will want to use J.D. Hygard or Lo-Vis Hygard depending on the temperature.
/ hydraulic oil #3
Ye. It will be right above the rear PTO. Yellow handle on it too.
2009 INTERNATIONAL SF647 GARBAGE TRUCK (A66091)
2009 INTERNATIONAL...
2014 INTERNATIONAL 7600 6x4 T/A DUMP TRUCK (A66091)
2014 INTERNATIONAL...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
