Oil & Fuel Hydraulic oil? Where did it go? YM1700B
   / Hydraulic oil? Where did it go? YM1700B #1
Ola, TX
Yanmar 1700B
I have had my YM1700B for a month. I went over everything and made repairs to radiator, which was the only aparent issue for the previsous owner.
Crank case oil was fine and now I seem to be very low on oil? No signs of leaks anywhere. Was moving dirt with the FEL when I heard a holllow sound from the hydralic pump. Mystery as to where the oil went.
Also can I use the Hydraulic oil that I have for my log splitter?
Michael
   / Hydraulic oil? Where did it go? YM1700B #2
Is the crankcase oil ok or over full? A high presure hydrolic leak can spray oil a long way. Wrap a cloth around the joints where the loader is spliced in. (most lickely place for a leak). UTF (universal tractor fluid) is most likely used in the trans/hydro.
Thanks for the input. Brought oil level up and everything is fine. You ask if the oil was over full? What was your comment it it was?
   / Hydraulic oil? Where did it go? YM1700B #4
With a FEL installed you'll have a higher hydraulic oil capacity than what's in the manual.. Have you changed that oil yourself? John Deere 303 is a good choice, but not the only one.
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
Toro Zero Turn (A50324)
Toro Zero Turn...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2017 VOLVO EC250EL EXCAVATOR (A51246)
2017 VOLVO EC250EL...
Massey Ferguson 231 Tractor with Loader (A51573)
Massey Ferguson...
