Oil & Fuel Hydraulic oil? Where did it go? YM1700B
   / Hydraulic oil? Where did it go? YM1700B #1
Ola, TX
Yanmar 1700B
I have had my YM1700B for a month. I went over everything and made repairs to radiator, which was the only aparent issue for the previsous owner.
Crank case oil was fine and now I seem to be very low on oil? No signs of leaks anywhere. Was moving dirt with the FEL when I heard a holllow sound from the hydralic pump. Mystery as to where the oil went.
Also can I use the Hydraulic oil that I have for my log splitter?
Michael
   / Hydraulic oil? Where did it go? YM1700B #2
Is the crankcase oil ok or over full? A high presure hydrolic leak can spray oil a long way. Wrap a cloth around the joints where the loader is spliced in. (most lickely place for a leak). UTF (universal tractor fluid) is most likely used in the trans/hydro.
Thanks for the input. Brought oil level up and everything is fine. You ask if the oil was over full? What was your comment it it was?
   / Hydraulic oil? Where did it go? YM1700B #4
With a FEL installed you'll have a higher hydraulic oil capacity than what's in the manual.. Have you changed that oil yourself? John Deere 303 is a good choice, but not the only one.
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
New/Unused CFG Industrial QK16R Mini Excavator (A51573)
New/Unused CFG...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51246)
2003 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
