Hydraulic oil top off
   / Hydraulic oil top off #1
8n Nut
Cosby, TN
Ford 8N, Ford Jubilee, Ford 2810
Recently got a 53 Ford Jubilee that needs its hydraulic oil topped off. Can I fill the fill inlet by the gearshift and expect it to go to all 3 areas thnat require hydraulic oil e.g. transmission, differential, and pump. It has only 1 hydraulic oil dipstick so I am assuming the 3 sections are connedted and overflow into each other. Thanks for helping. 8n nut
   / Hydraulic oil top off #2
Sorry.. don't work that way.
Did you notice that theye are 2 other fill locations? One under the front left of the seat.. and one behind the right rear of the seat.
trans is a single sump.
hyds is a single sump
diffy is a simgle sump.
PS.. I would advise against using plain hyd oil. A UTF oil meeting ,2c134 specs ( most all do these days ), is the preferred choice.
hyds has a dipstick.
diffy has a check plug left side of pto shaft.
trans has a check plug. right side of trans, about where yer heel rests, above the running board level. it's a plug not a bolt.. DO NOT remove any bolts from the side of the tranny or you will be posting back with even more questions.. :)
   / Hydraulic oil top off #3
A jub manual would help cause there's a lot of changes between the jub and 8N. Welcome to the world of live hydraulics.
Kirk
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
Woven Landscape Fabric (A53117)
Woven Landscape...
2015 TEXAS PRIDE  GOOSENECK (A53843)
2015 TEXAS PRIDE...
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
2012 Subaru Legacy Sedan (A51694)
2012 Subaru Legacy...
72'' skid steer bucket (A53421)
72'' skid steer...
