Hydraulic oil top off
   / Hydraulic oil top off #1
8n Nut
Cosby, TN
Ford 8N, Ford Jubilee, Ford 2810
Recently got a 53 Ford Jubilee that needs its hydraulic oil topped off. Can I fill the fill inlet by the gearshift and expect it to go to all 3 areas thnat require hydraulic oil e.g. transmission, differential, and pump. It has only 1 hydraulic oil dipstick so I am assuming the 3 sections are connedted and overflow into each other. Thanks for helping. 8n nut
   / Hydraulic oil top off #2
Sorry.. don't work that way.
Did you notice that theye are 2 other fill locations? One under the front left of the seat.. and one behind the right rear of the seat.
trans is a single sump.
hyds is a single sump
diffy is a simgle sump.
PS.. I would advise against using plain hyd oil. A UTF oil meeting ,2c134 specs ( most all do these days ), is the preferred choice.
hyds has a dipstick.
diffy has a check plug left side of pto shaft.
trans has a check plug. right side of trans, about where yer heel rests, above the running board level. it's a plug not a bolt.. DO NOT remove any bolts from the side of the tranny or you will be posting back with even more questions.. :)
   / Hydraulic oil top off #3
A jub manual would help cause there's a lot of changes between the jub and 8N. Welcome to the world of live hydraulics.
Kirk
Husqvarna YTH 18542 Riding Mower (A53117)
Husqvarna YTH...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
