Hydraulic oil question
/ Hydraulic oil question #1
bergenfelter
Edwards, IL
Kubota GR2110
Went to the Kubota dealer to pick up a quart of hydraulic oil. He told me I could use the New Holland/Ambra Multi G 134 oil - it was the same as the Kubota oil. Thoughts?
/ Hydraulic oil question #2
Be prepared for anything on oil/lubricant threads. I used Ambra in my first BX a 2003 BX2200 and it is still running like a top. My dealer at that time was a Kubota and NH and he didn't even stock UDT or SUDT.
I have used several different brands of good quality fluid from Ambra, Kubota, Case etc.
/ Hydraulic oil question #3
There are many good fluids out there. Use the fluid you are using and have fun.
/ Hydraulic oil question #4
Since you only asked for a quart, I assume you are topping off the fluid? If it was me, I would want the same oil that is already in the system.
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A61574)
2005 20 Ft...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
