Oil & Fuel Hydraulic oil leak
/ Hydraulic oil leak #1
70 plus
Uxbridge, Ontario
Kubota B3200, JD LT 166, JD 110
Hi Folks
My 2009 Kubota B3200 HST with about 400 hours on it has sprung an hydraulic oil leak from what appears to be a join down the side of the radiator in the pipes used to run the hydraulic oil in front of the radiator to cool the oil.
I've attached a picture and wonder if anyone has run into a similar problem and if it was difficult to fix?
Thanks
/ Hydraulic oil leak #2
You need a new o-ring. While you are at it, why not replace them on both sides since it comes in a pack of 2 anyways.
KPN: 04816-00120 O RING QTY - 2
Thank you I can pick them up.
I did not realize that they were on both sides.
Is the process to replace the o ring difficult? Any u-tube videos out there?
Cliff
/ Hydraulic oil leak #4
Cliff
Yes, there will be one on each side.
No YouTubes from what I can see.
Here's what I'm referring to:
Red is the connections to the hyd oil cooler, the orange are the o-rings.
That is great thanks.
It looks like I just have to remove the parts numbered 180 which look like clips, replace the O rings and the replace the clips.
Think I can manage that.
Appreciate the help.
Cliff
/ Hydraulic oil leak #6
Exactly. Shouldn't be hard.
Just remember to have a quart or two (or as much as you lost) of Super UDT2 to top it back off. You are going to lose some when you do this.
Also, before working on it, clean the area of work to avoid getting contamination.
Will do. Thanks
Hi diesel85
Well the temperature her finally got to up to about 40 F after a few weeks of -20 F so I was able to work on the tractor down the barn and got the O rings replaced.
All is well no leaks and I'm ready for the next snowfall.
Thanks again, I would not have tackled the job without your input and diagram.
Cliff
Will do. Thanks
/ Hydraulic oil leak #9
Excellent! Good to hear!
Glad the tips helped.
/ Hydraulic oil leak #10
diesel85, you get a good citizen award. It is just such helpfulness that makes this forum (and others, no doubt) so great and useful.
Thanks
/ Hydraulic oil leak #11
I've got the same problem but the clip is broken, do you happen to know the part number for the clip #180
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
Deere 350G LC (A53317)
John Deere 5075E (A53317)
John Deere 5075E...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
