Hydraulic oil friction reducer
   / Hydraulic oil friction reducer #1
rock3322
hutchinson, ks
toolcat plus many
Has anyone tried a friction reducer in your hydraulic system? If so what did you use and how did it work?
   / Hydraulic oil friction reducer #2
What problem does "friction reducer" solve that good quality clean oil not address?
I've been against additives since a can of "motor honey" caused my 1967 volkswagen to "suck a valve" 35 years ago. I thought at the time that I was being extra special nice to my vehicle.
   / Hydraulic oil friction reducer #3
I've never heard of this stuff and even ran a Google search and couldn't find anything. My understanding is that the hydraulic oil has the same consistency of a 5W30 motor oil.
DEWFPO
A good friction reducer could help in the drive motor issues..
   / Hydraulic oil friction reducer #5
Best thing to do is make sure you warm your machine up before putting in road gear. Diff fluid stays a bit sticky until you do, feels like your trying to pull a train. Run it for a block or two in low range and that should warm it up. If your having other problems it might be a filter or low fluid.
Rooster Weathervane (A55853)
Rooster...
2018 JLG 3246ES 32ft Electric Scissor Lift (A53421)
2018 JLG 3246ES...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A57024)
2021 John Deere...
