Hydraulic Oil Filter
   / Hydraulic Oil Filter #1
Jagmandave
Veteran Member
Olathe, Ks
Yanmar 1602D
Has anyone ever changed one of these without draining the trans first? Can it be done or do you drown in Hydraulic oil?
I just added 2 gal after repairing a broken loader hose, so I hate to replace it again.............
   / Hydraulic Oil Filter #2
Don't know, but you could drain it and then put the same stuff back in.
   / Hydraulic Oil Filter #3
Yes, I would drain it. I think I would get new fluid but I would drain it before I messed with the filter.........Fluid is cheap compared to hydraulic repairs........
   / Hydraulic Oil Filter #4
If you have the spin type, you lose about a quart if you are fast.
It's a spin on, looks like the original filter! 'preciate the advice!
   / Hydraulic Oil Filter #6
If this is your first time make sure you have the correct filter for it. Some look right and will even go on there correctly but if the mesh is too fine you may have problems. I tried a $10 NAPA hydraulic filter instead of the more expensive Yanmar filter and it would not work on the YM2620 that I had.
Thanks again, I had already bought a Yanmar filter from Hoye. I pretty much always use factory parts whenever they're available.
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
(1) FRIGIDAIRE REFRIGERATOR (A51248)
(1) FRIGIDAIRE...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
