Oil & Fuel Hydraulic oil coming from shifter boot
   / Hydraulic oil coming from shifter boot #1
BTackett
Knoxville, Tn
I checked the dipstick beside the shifter on the YM1700 and it is about 3/4 inch above the XXXXX on the stick. Could this be the cause? It was recently changed and I think too much was refilled causing the leaking. Also my RRear axle seal drips a couple of drops at night after using.
Should the level be in between the XXXXX on the flat spot? Is there a drain plug besides pulling the filter out?
thanks.
Bill
   / Hydraulic oil coming from shifter boot #2
Have you checked the shifter boot for cracks , Tight seal,etc, The oil fill should be within the x's. Top x being full
   / Hydraulic oil coming from shifter boot #3
Yes, it should be between those lines. I'm not sure if 3/4" would make it leak or not though. If you drain a little out & it still leaks- check your breather vent. A plugged breather is a very common cause of shifter boot leaks. It is #8 here--
THREE_POINT_LIFT: Yanmar Tractor Parts
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / Hydraulic oil coming from shifter boot #4
yea i had lots of pressure coming out of my dipstick on transmission. I used to keep it kind of loose unitill i found out about the breather problems. I took mine off and it was totaly clogged. now no more pressure coming out of the dip stick.
Later
erick
   / Hydraulic oil coming from shifter boot #5
I would check the transmission vent. I recently bought a Yanmar YM1500. After tilling my large garden, I found fluid leaking around the gear shift boot and the PTO seal. I read a post from Aaron about the transmission vent. Checked mine and it was broken and bent closed. Went to Tullahoma Tractor (where I bought the YM1500) and got a new vent tube. Installed the new vent tube. Problem disappeared.
I checked the vent tube under the seat and it is clear. I remove it and it has no obstruction. Is there another vent that I am missing? Maybe one on the tranny?
Bill
   / Hydraulic oil coming from shifter boot #7
The vent I was referring to is the curved tube under the seat.
   / Hydraulic oil coming from shifter boot #8
Bill
I don't think so. Mine had a dirt dabber nest in it one time and mine started leaking out of the boot. I cleaned that out with a piece of wire and it stopped leaking. You may just have a bad boot.
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
Coleman Go Cart (A51573)
Coleman Go Cart...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
2018 Peterbilt 389 Day Cab Truck, VIN # 1XPXD49X8JD476306 (A51572)
2018 Peterbilt 389...
