Oil & Fuel Hydraulic oil coming from shifter boot
   / Hydraulic oil coming from shifter boot #1
BTackett
Knoxville, Tn
I checked the dipstick beside the shifter on the YM1700 and it is about 3/4 inch above the XXXXX on the stick. Could this be the cause? It was recently changed and I think too much was refilled causing the leaking. Also my RRear axle seal drips a couple of drops at night after using.
Should the level be in between the XXXXX on the flat spot? Is there a drain plug besides pulling the filter out?
thanks.
Bill
   / Hydraulic oil coming from shifter boot #2
Have you checked the shifter boot for cracks , Tight seal,etc, The oil fill should be within the x's. Top x being full
   / Hydraulic oil coming from shifter boot #3
Yes, it should be between those lines. I'm not sure if 3/4" would make it leak or not though. If you drain a little out & it still leaks- check your breather vent. A plugged breather is a very common cause of shifter boot leaks. It is #8 here--
THREE_POINT_LIFT: Yanmar Tractor Parts
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / Hydraulic oil coming from shifter boot #4
yea i had lots of pressure coming out of my dipstick on transmission. I used to keep it kind of loose unitill i found out about the breather problems. I took mine off and it was totaly clogged. now no more pressure coming out of the dip stick.
Later
erick
   / Hydraulic oil coming from shifter boot #5
I would check the transmission vent. I recently bought a Yanmar YM1500. After tilling my large garden, I found fluid leaking around the gear shift boot and the PTO seal. I read a post from Aaron about the transmission vent. Checked mine and it was broken and bent closed. Went to Tullahoma Tractor (where I bought the YM1500) and got a new vent tube. Installed the new vent tube. Problem disappeared.
I checked the vent tube under the seat and it is clear. I remove it and it has no obstruction. Is there another vent that I am missing? Maybe one on the tranny?
Bill
   / Hydraulic oil coming from shifter boot #7
The vent I was referring to is the curved tube under the seat.
   / Hydraulic oil coming from shifter boot #8
Bill
I don't think so. Mine had a dirt dabber nest in it one time and mine started leaking out of the boot. I cleaned that out with a piece of wire and it stopped leaking. You may just have a bad boot.
53ft refer trailer (A51694)
53ft refer trailer...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
1992 GROVE CRANE (A52576)
1992 GROVE CRANE...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
Vermeer BC1800A Wood Chipper (A51573)
Vermeer BC1800A...
