Hydraulic oil change--any tips for refilling??
   / Hydraulic oil change--any tips for refilling?? #11
   / Hydraulic oil change--any tips for refilling?? #12
Both times I changes hydraulic oil I rivaled the Exxon Valdez for oil spillage.
   / Hydraulic oil change--any tips for refilling?? #13
That's what I'm afraid of
I'll need help with the cleanup
   / Hydraulic oil change--any tips for refilling?? #14
Set a large, clean bucket up high on the tractor. Put some tubing from your fill hole into the bucket. Pour some new oil in the bucket and tilt it to get the air out of the tube. After that, just keep pouring your new oil containers into the bucket.
Finally did it today--warm temps and sunny skies. I went to Walmart and bought a 34 quart storage bin with nice low sides. Started by draining the out drives first and transferring the 4+ gallons of oil to old gallon jugs I had saved. Then came the black hydraulic filter and the orange HST filter and finally the big, magnetic drain plug. I found just one metallic shaving that looked like a drill turning. Then came the hardest part--refilling. I duck taped a long neck funnel to the top link I suspended from the retaining hook and refilled one gallon at a time after transferring the oil into a 5 qt. jug from the two five gallon pails I bought at TSC. Total cost was $68 for the oil, $68 for the two filters, $7 for the bin and $6 for the beer. Thanks to all of you for your suggestions.
   / Hydraulic oil change--any tips for refilling?? #16
And how long to clean up the buckets, jugs, funnels and stuff after you finished, Retired Guy? ;)
2019 CATERPILLAR 226D SKID STEER (A52709)
2019 CATERPILLAR...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
Giyi Excavator 44" Rake (A57149)
Giyi Excavator 44"...
1969 VOLKSWAGEN BUG (A59575)
1969 VOLKSWAGEN...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
UNUSED FUTURE 32"...
