Hydraulic oil change--any tips for refilling??
   / Hydraulic oil change--any tips for refilling?? #11
   / Hydraulic oil change--any tips for refilling?? #12
Both times I changes hydraulic oil I rivaled the Exxon Valdez for oil spillage.
   / Hydraulic oil change--any tips for refilling?? #13
That's what I'm afraid of
I'll need help with the cleanup
   / Hydraulic oil change--any tips for refilling?? #14
Set a large, clean bucket up high on the tractor. Put some tubing from your fill hole into the bucket. Pour some new oil in the bucket and tilt it to get the air out of the tube. After that, just keep pouring your new oil containers into the bucket.
Finally did it today--warm temps and sunny skies. I went to Walmart and bought a 34 quart storage bin with nice low sides. Started by draining the out drives first and transferring the 4+ gallons of oil to old gallon jugs I had saved. Then came the black hydraulic filter and the orange HST filter and finally the big, magnetic drain plug. I found just one metallic shaving that looked like a drill turning. Then came the hardest part--refilling. I duck taped a long neck funnel to the top link I suspended from the retaining hook and refilled one gallon at a time after transferring the oil into a 5 qt. jug from the two five gallon pails I bought at TSC. Total cost was $68 for the oil, $68 for the two filters, $7 for the bin and $6 for the beer. Thanks to all of you for your suggestions.
   / Hydraulic oil change--any tips for refilling?? #16
And how long to clean up the buckets, jugs, funnels and stuff after you finished, Retired Guy? ;)
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
UNUSED CFG INDUSTRIAL H12R EXCAVATOR (A58375)
UNUSED CFG...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2015 CHEVROLET SILVERADO 1500 (A58214)
2015 CHEVROLET...
1998 Mazda B2500 (A57148)
1998 Mazda B2500...
SDLanch SDLGC100 Crew Electric Golf Cart (A57149)
SDLanch SDLGC100...
