careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,689
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
Your gear drive transmission is not a dry transmission else there would not be seals on the rear drive axle or PTO shaft. So while pressure may inly he required by lifting your 3ph, it is far from the only thing using that fluid. And the pump runs while the engine runs.
Please quit promoting false information to others who may not have knowledge to recognize misinformation. While the gears in your transmission may be more of splash bath, it still uses the fluid!
Otherwise why dies a differential or transfer case in a truck have fluid?
Another Yikes!! only thing I was referring to was the Hyd. Pump. I didn't know I needed to wright a novel on every seal on the tractor Dang!!! or uses the fluid for that matter..........:confused2:
